8 years ago[Cyclone V PCIe Hard IP]: Avalon to PCIe read issue
Dear all, We are using Cyclone V PCIe Hard IP core with Quartus 16.1. We are using requester/completor mode so that we can perform PCIe read and write operations from Avalon master. In our d...
8 years agoHello, Bhaumik
I've had the same problem on completing read operations (move data from the offchip memory to an internal module) for the Arria 10 device using a similar PCIe Hard IP and External Memory Interface controller. The master interface generated a read request and slave accepted it by de-asserting wait_request but not generating the readdata_valid flag. It turned out that I have a problem with my burstcount values. The following changes solved the problem: 1 - I had to make sure that master and stave burstcount ports had the same width; 2 - Burstcount values, in my case, had to be 7 bits long but the max burst value should less than or equal to 2^6 = 64. Even so, I notice that internally the external memory interface splits bursts greater than 8 into several small 8 words bursts. Remember that bursts are counted in number of blocks, not words. I mean, if your emif readdata port is 512bits long (16 words), a burst value 8 will generate 512*8 bits answer (128 words). The readdata_valid signal will be up for 8 clock cycles, with each cycle bringing 512 consecutive bits from the external memory. I hope this information will help you. Regards
