9 years agoCyclone V PCIe Avalon-MM IP missing from Quartus Prime
This seems like a pretty simple question, but I am stumped as to why I do not see the Cyclone V PCIe Avalon-MM IP in Quartus Prime. I have tried Quartus Prime (Standard Edition) versions 17.0, ...
9 years agoNot sure. The MM version is certainly available and compatible with Cyclone V. It may be a mix of other parameters that are preventing it from working. For example, the MM version for Cyclone V does not support a multi-function endpoint, while the ST version does. Check your other parameter settings to see if something else is preventing you from using the MM version.
