8 years agoCyclone V Hard Memory Controller MPFE bandwidth
I have a QSYS design which uses DDR memory. The DDR memory is clocked at 400Mhz in the Hard Memory Controller, and is 32 bits wide, so max bandwidth (not allowing any latency!) is 2*400,000,000*32 = ...
8 years agoNot entirely, there was some issue between how the two ports were shared between the various things using them, so that was tidied up, and we then made some compromises in terms of what resolutions one pipe ran at, etc. I seem to also remember there was some error in my calculations of actual available bandwidth to/from the MPFE ports, but haven't got the calculations with me.
Good luck with your design, Simon
