JBayl
7 months agoCyclone 10GX PCIe / Raspberry Pi
Hi, We have a PCIe controller using the Cyclone 10Gx with the PCIe hard IP. It works when connected to a Windows system but it isn't getting detected when connected on a Raspberry Pi 5 or CM5 syste...
Wincent_Altera
7 months agoHi,
Which design that you are using ? is it a custom design or the design generated from the Quartus IP catalog ?
I would suggest to try from the example design.
If it is stuck at Detect.Active it seen like the board connection problem in most of the time.
Can you share with me a simple block diagram how you connect the C10 with the Raspberry Pi ?
Wincent_Altera
