PROMA
6 years agoCyclone 10 LP PLL output to pin assignment
I have a design with a Cyclone10 LP that needs to talk to a RGMII PHY, which expects a clock signal.
I use a PLL to generate a 125 MHz clock, and would now like to route that to an output pin which is PLL4_CLKOUTp.
The fitter returns me the following warning:
Warning (15064): PLL "PLL_Cy10LP:PLL_inst|altpll:altpll_component|PLL_Cy10LP_altpll:auto_generated|pll1" output port clk[3] feeds output pin "SC3_ETH0_TX_CLK~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
Do you have any idea on how to solve this warning?
1 Reply
- AnandRaj_S_Intel
Hi Pannet,
If you have connected to Pll output pin to PLL4_CLKOUTp.
You can ignore the warning.
Anand
