KeeganJ
5 years agoCyclone 10 GX Transceiver Reset Controller "LockedToData" Signal
I'm instantiating the reset controller IP in order to safely use the the Cyclone 10 GX transceivers, as described in the user manual.
My question is why does the reset controller require "rx_is_loc...
Deshi_Intel
5 years agoHI,
Just want to follow up with you.
How does it go with your hardware testing ?
dlim
- KeeganJ5 years ago
Well I wired "rx_is_lockedtoref" into the reset controller, as mentioned. As best as I can tell it is working... I'm getting 10Gbps of data from the transceiver into the fabric, and the data looks right (again we are oversampling a slower signal, no serial clock to recover).
So I guess either it's working or it's not failing in a way that I have been able to observe so far.
