Cyclone 10 GX Simulation Files
- 2 years ago
Below is engineering's feedback:
Simulation netlist (which customer is using) is not meant for formal verification.
having said that we should be including all parameters in the ATOM instances in simulation netlist.
From engineering feedback, it seems that the simulation netlist generated is not meant for OneSpin formal verification.
When formal verification is enabled(set_global_assignment -name ENABLE_FORMAL_VERIFICATION ON), I checked that these are the verilog netlist generated under the project directory:
verification/
rtl/ (This directory contains all rtl files)
elaborated/ (Directory contains files used in RTL vs Elaborated Verification)
synthesized/ (Directory contains files used in Elaborated vs Synthesized Verification)
planned/ (Directory contains files used in Synthesized vs Planned Verification)
placed/ (Directory contains files used in Planned vs Placed Verification)
routed/ (Directory contains files used in Placed vs Routed Verification)
retimed/ (Directory contains files used in Routed vs Retimed Verification)
final/ (Directory contains files used in Routed/Retimed vs Finalized Verification)
You could perform Formal Verification at each stage
elaborated : To verify RTL vs elaborated netlist
synthesized : To compare elaborated vs synthesized netlist
planned: To compare synthesized vs planned netlist
placed: To compare planned vs placed netlist
routed: To compare placed vs routed netlist
retimed: To compare routed vs retimed netlist
final: To compare routed/retimed vs finalized netlist
Will inform if there is further update from the engineering.
Richard Tan
Is this behaviour can be duplicated using the previous design provided (iostandards_compare.v)?
I am unable to compile those files. Could you shares a simplified Quartus project .qar ?
Thank you.
Richard Tan
Using the files that I gave you should produce the same thing with the setting of:
This produced a verification directory. Inside of this verification directory, inside of the verification directory it produced a .sv. I believe this is what you wanted me to look at. This sv contains the Verilog with the differential_mode set correctly. This model is a twentynm_ component. This is fine if this is the method that we need to go from here, from examining the differences between the two components in the atoms files, it is mostly just the names of them.
Getting you a .qar could take quite a bit, but I would think the engineer you talked to previously could answer this very easily. If I can produce a cyclone10gx by using twentynm models, this shouldn't be too much of an issue.
- RichardT_altera2 years ago
Yes, you are right. They are the same, you can either use the twentynm_io_ibuf or the cyclone10gx_io_ibuf.
Richard Tan
