Cyclone 10 GX Simulation Files
- 2 years ago
Below is engineering's feedback:
Simulation netlist (which customer is using) is not meant for formal verification.
having said that we should be including all parameters in the ATOM instances in simulation netlist.
From engineering feedback, it seems that the simulation netlist generated is not meant for OneSpin formal verification.
When formal verification is enabled(set_global_assignment -name ENABLE_FORMAL_VERIFICATION ON), I checked that these are the verilog netlist generated under the project directory:
verification/
rtl/ (This directory contains all rtl files)
elaborated/ (Directory contains files used in RTL vs Elaborated Verification)
synthesized/ (Directory contains files used in Elaborated vs Synthesized Verification)
planned/ (Directory contains files used in Synthesized vs Planned Verification)
placed/ (Directory contains files used in Planned vs Placed Verification)
routed/ (Directory contains files used in Placed vs Routed Verification)
retimed/ (Directory contains files used in Routed vs Retimed Verification)
final/ (Directory contains files used in Routed/Retimed vs Finalized Verification)
You could perform Formal Verification at each stage
elaborated : To verify RTL vs elaborated netlist
synthesized : To compare elaborated vs synthesized netlist
planned: To compare synthesized vs planned netlist
placed: To compare planned vs placed netlist
routed: To compare placed vs routed netlist
retimed: To compare routed vs retimed netlist
final: To compare routed/retimed vs finalized netlist
Will inform if there is further update from the engineering.
Richard Tan
Thank you for understanding. I will wait for your example project.
It would be helpful if you could provide any screenshots that might show the results.
Richard Tan
- MKwiec2 years ago
Sample files that show this
