mgiordan
1 year agoCXL Type 3 + AXI Reg slice causing system deadlock
Hi all, I'm currently using the CXL Type 3 IP, and am encountering the following issue. Whenever I hook up the CXLIP directly to the MC, things work fine. However, when I place an AXI register slice...
RongY_altera
Contributor
1 year agoPlease check afu_top.sv. You may add your codes in this passthrough module.
Rong
