Raj_G
3 years agoCXL Example Design simulation: Illegal combination of drivers
Running the simulation of the CXL Example Design, following the CXL_Reference_Designs_User_Guide_v1.5.pdf document, gives the following errors during elaboration:
Error-[ICPD_INIT] Illegal co...
JohnT_Altera
3 years agoHi,
Can you double confirm the directory is correct? May I know what is the changes made?
- RicardoC3 years ago
Hi John,
I ran "which quartus", and I got the following:
[cxltyp3ddr_tb_22p4]$ which quartus
/shared/opt/intel/intelFPGA_pro/22.4/quartus/bin/quartus
[cxltyp3ddr_tb_22p4]$ set | grep QUARTUS
QUARTUS_INSTALL_DIR=/shared/opt/intel/intelFPGA_pro/22.4/quartus
QUARTUS_LIB_DIR=/shared/opt/intel/intelFPGA_pro/22.4/quartus
[cxltyp3ddr_tb_22p4]$Can you confirm if these are correct?
Can you be more specific on which changes you are referring to?
Thank you,
Ricardo.
- OliverJacob123 years ago
@RicardoC wrote:
Hi John,
Thank you,
Ricardo.
Could you please share the procedure to run the design example using VCS Mx instead of VCS?
