ss
5 years agoCVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never starts up. Any suggestions? The BFM is working to configure the TPG.
- CheepinC_altera
I believe Sherman has helped to feedback to you on the workaround to use Q20.3Pro. I will set this case to close and we shall continue to follow up in IPS if there is any further inquiries.
Thank you very much.
