CVO simulation configuration
As I understand it, there is no issue when you are simulating with TPG -> CVO. The issue happen when you are using a module to real time configure the CVO. To ensure we are on the same page, just to check with you what is referred by "MM BFM"?
Chee Pin
- ss6 years ago
By MM BFM I am referring to the Avalon-MM Master BFM Intel FPGA IP.
My problem seems more basic than I originally thought. I have done quite a bit of simulation of the video path on the previous project using Quartus Std 18.1.
I am now using Quartus Pro 20.2 on an Arria project. I can't get any video out of the Clocked Video Output module using the most basic system (clk, reset, TPG, CVO). I have tried many presets and alignments of ready and reset between the two modules with no success. This is simple stuff compared to my previous project. I'm not sure what has changed and why it does not work. Do you have a simple design like this that you can share with me?
-Steve
