Custom IP Composed Component generation using _hw.tcl
- 5 years ago
Hi @cosx
Sorry for the late reply. Do you need further help regarding to this case? Do you able to solve the issue?
*A composed component is a subsystem containing instances of other components.
*Unlike an HDL-based component, a composed component's HDL is created by generating HDL for the components in the subsystem.I don't think you need to defined the synthesized fileset of all files in the composed component as this was defined prior in each _hw.tcl file of each sub IP.
Richard Tan
Thank you so much for your reply!
My second point is more about composed IP generation. Currently the document did not give any example code of the whole generation.
For instance, if I have a composed IP that contains 3 sub customised IPs, how can I generate this composed IP?
Do I just need to add synthesized fileset of all files and then the composed IP .v is generated, or need extra commands?
Could you please give me a bit more details of this if possible?
Thank you again!
Mingqiang
Hi @cosx
Richard Tan
