Evan44
3 years agoCreating HDMI TX only (no Nios) solution targeting Cyclone 10 GX Dev Kit
I am looking to create a simple HDMI TX demonstration of sending a fixed RGB video pattern to a sink monitor while targeting the Cyclone 10 GX development kit. I don't want to use Nios, and it appe...
ZH_Intel
3 years agoHi Evan44,
Thank you for your patience.
Regarding to your question, yes you are correct, to implement a TX only design you need to add TPG and CVO into the design.
At the moment, all our HDMI design example uses NIOS for flow control.
If you wish to design TX only without NIOS, you need to implement the C function into the RTL code.
You may locate the C code in designfile/software/tx_control_src/.
Hope this answers your question.
Thank you.
ZulsyafiqH_Intel
