JHaye4
6 years agoConstraints warning from async_clock_corsser
I am using a QSYS in my design and get the following warnings when compiling. I am instantiating a clock, constraining it correctly, and feeding it to the QSYS so I'm not sure what is going on.
- 5 years ago
Hi James,
I received the feedback from engineering. These warnings can be safely ignored. You may also use the sdc that I emailed to you to fix the warning.
KhaiY
KhaiChein_Y_Intel
5 years agoHi James,
KhaiY
- JayHarikumaran5 years ago
Hello KhaiY,
I am also receiving the same error as listed in the original post. I am using quartus prime lite 21.1. Could I ignore these warnings and assume that the constraint is actually implemented in the timing based compilation?Regards
Jay
