Constraints warning from async_clock_corsser
- 5 years ago
Hi James,
I received the feedback from engineering. These warnings can be safely ignored. You may also use the sdc that I emailed to you to fix the warning.
KhaiY
Error below occurred during QSYS HDL generation.
Error: sys_f1_amm_conduit_fl_24b_0.amm_conduit_fl_24b_0: Component amm_conduit_fl_24b 1.0 not found or could not be instantiated
Error: qsys-generate failed with exit code 3: 1 Error, 5 Warnings
Besides this, the warning in the description indicates that there is no valid clocks found between the given points. You have to verify that there is a valid clock between the from and to collection.
I can help you to check if you could provide the full design QAR. To generate QAR file, click on Project > Archive Project > Archive
KhaiY
- JHaye46 years ago
Sorry for that, I have removed that specific IP from the QSYS as it is not related to the issue I'm having.
I have attached my QAR as requested, thank you very much.
