14 years agoConnecting an 8-bit peripheral to a 32-bit avalon bus
Hello, I am connecting an I2C core to a ColdFire V1 IP Core using the Avalon Bus in SOPC. I get a warning about the slave (I2C core), which has 8-bit registers, not having byteenables. Then it ...
14 years agoIt is actually has an AMBA bus but has a wrapper on it so that it works with the SOPC/Avalon bus. I wasn't using the byteenables. I will try using them as per the suggestion. THanks.
.abyteenable (abyteenable) // output: 4-bit Byte Enable [3]=31:24 [2]=23:16 [1]=15:8 [0]=7:0
