14 years agoConnecting an 8-bit peripheral to a 32-bit avalon bus
Hello, I am connecting an I2C core to a ColdFire V1 IP Core using the Avalon Bus in SOPC. I get a warning about the slave (I2C core), which has 8-bit registers, not having byteenables. Then it ...
14 years agoBoris thanks for responding. Okay, now why do I need 2 bits for byte enable? I have the following code for the writing of internal 8-bit registers using just 3 bits of the address for the write and just one byte for the write data register :
// avalon signals input clk; // master clock input input reset_n; // asynchronous reset input [2:0] address; // lower address bits output [7:0] writedata; // databus output input wr; // write input input rd; // read input reg [7:0] writedata; always @(posedge clk) begin //if (~wr & rd) if (wr & ~rd) case (address) // synopsys parallel_case 3'b000: writedata <=# 1 prer[ 7:0]; 3'b001: writedata <=# 1 prer[15:8]; 3'b010: writedata <=# 1 ctr; 3'b011: writedata <=# 1 rxr; // write is transmit register (txr) 3'b100: writedata <=# 1 sr; // write is command register (cr) 3'b101: writedata <=# 1 txr; 3'b110: writedata <=# 1 cr; 3'b111: writedata <=# 1 0; // reserved endcase end
