Configuring a PLL
- 2 years ago
From the device handbook, it mentioned that the Cyclone III device family does not
contain dedicated serialization or deserialization circuitry. Therefore, shift registers,
internal phase-locked loops (PLLs), and I/O cells are used to perform serial-to-parallel conversions on incoming data and parallel-to-serial conversion on outgoing data. The differential interface data serializers and deserializers (SERDES) are automatically constructed in the core logic elements (LEs) with the Quartus® II software ALTLVDS megafunction.
I don't understand all details of your interface, specifically I'm not aware of "synchronization line" playing a role in MIPI camera interface. As far as I know, MIPI is using serial data rates above 1 GBPS per lane. Maximal data rate achievable with Cyclone III SERDES is 875 MBPS (depending on FPGA speed grade). Therefore it can't receive MIPI data.
- UMall12 years ago
I am using an On Semi chip - the rate is 720Mbps. The synchronization line carries readout state - Frame Start, Line start, Frame end, Line End, CRC, Image etc. When I design the PLL I see that - despite having Cyclone III as the implementation chip - Quartus shows a - "Can implement Interface" message. I use the Cyclone III EP3C80F484C6 FPGA. 720Mbps seems to be well within the chip's abilities.
