14 years agoCombine DSP Builder and Quartus II Project
Hi! I wanted to ask, if it is possible, to combine a DSP Builder Project with a Quartus II Project. I know how to compile a DSP Builder Project in Quartus II. For my case, I would li...
14 years agoDSP Builder doesn't automatically create Pin Assignments unless you add a Pin Assignment blocks or add a Virtual Pins block. If you have done those, they will be created into the output directory when DSP Builder is generating.
I don't think they can be added to a qip file, so you would have to manually invoke the pin assignments script generated by DSP Builder. I haven't tried this so you'd have to experiment.
