14 years agoCombine DSP Builder and Quartus II Project
Hi! I wanted to ask, if it is possible, to combine a DSP Builder Project with a Quartus II Project. I know how to compile a DSP Builder Project in Quartus II. For my case, I would li...
14 years agoThank you for you answer!
I included a small self made and compiled dsp builder project in an empty quartus II project. I used the tcl command line and executed the "source <file directory>/*_add.tcl" file, which was generated from simulink. Then I had, as you mentioned, the *.mdl and *.mdlxml files in my quartus Project. I compiled it and afterwards I saw all the vhd files in the Hierarchy. But in the File Window there were only the mdl and mdlxml files. Do I have to import the generated vhd files from the <project>/db directory manualy then? Do I have to create symbols then for each vhd file? In the end I would like to have a schematic as top level entity file where i can integrate the dsp builder project (or parts of the project) as black box. I think I still make a mistake somewhere.
