16 years agoColor Plane Sequencing
Hello, I'm trying to utlize the Median Filter in SOPC. I've managed to connect a Clocked Video Input module to a Clocked Video Output Module no problem and pass-thru video data. So CVI -> CVO...
16 years agoThe following configuration seems to work correctly:
Test Pattern (seq. RGB) -> Median Filter -> Color Plane Seq. (Par. RGB) -> Clocked Video Output (Par. RGB) With the following clocking: Test Pattern = 3x video clock Median Filter = 3x video clock Color Plane Seq. = 3x video clock CVO = 1x video clock I get a nice test pattern out of the above. Ok, so now I put the following into the data chain CVI (par. RGB) -> CPS (seq. RGB) -> Median Filter -> CPS (par. RGB) -> CVO (par RGB) With the following clocking: CVI = 1x video clock Color Plane Seq. = 3x video clock Median Filter = 3x video clock Color Plane Seq. = 3x video clock CVO = 1x video clock And this design fails - no switching on any of the video outputs at all, HSYNC, VSYNC and Valid all dead. I would think its because the CVI -> CPS clocking is somehow incorrect where we would want the CPS to run at 1x video clock when going from parallel RGB to sequential RGB. What is the correct thing to do here as I cannot modify the CPS clock in the SOPC to account for this discrepancy. Thanks, Mike
