17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoAs far as your luma chroma swap. As you are doing it serially I can think of two ways to handle the problem.
1 - I would just write a small HDL block after the clocked video output that would resequence the data. 2 - You could try the Altera Color Plane Sequencer just before the Clocked Output block. Jake
