17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoDo you think such a structure is feasible.... Can i do without a frame buffer at the end?
Or will i get a buffer under run? Is there any better way you all can suggest to be able to send a video feed to be able to be shown on a screen and recorded on an sd card at the same time? I thought before the entrance to each of the interfaces i would put a ONChip Fifo, which would be dual clock hence allowing me to run the system at different clock speeds.. I hope you all dont mind giving me ideas, thanking you nadeem jamal
