17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoAusom thanks to both of you Jkob and thiago, Thanks for the code , is helpfull for sure.
Sorry I am not clear on how i could switch my luma and chroma, as i am sending them out with a 8 bit bus in sequence( serially). Only 8 bits are going from my Clocked out IP to video IC chip.... Another side question hope you all don't mind... I have decided to use a SGDMA controller to send data from my SRAM to multiple interfaces , such as ->Onchip Fifo-> USd Card SGDMA Controller -> Colorizor-->CSC->Chroma re sampler-> Scaler->Clocked->Video Out.
