17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoNote to anyone using that code, it assumes the first vertical falling edge occurs at line 0. This is no impact for 3G/HD standards but the line numbers for the SD standards are offset accordingly.
Jake
