17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agohey thiago, thanks alot for your quick reply.
Actualy come to think about it , I said the wrong thing. I have set it to 8 bits, 2 symbols, in sequence and not parallel (hence one symbol per beat i guess ... Is this right). I initial tried 1, but had no luck. Well i get an 8 bit out video data, which i connect to my ADV7171( although the adv has option of using 16 bit interface, i have set it up to use only 8 bits. But I am not sure what to do with the Data Valid signal.DO u leave it unconnected? I am sure the ADV is connected properly and is set right, as i can enable and disable the in build Test pattern generator, plus when download the SOF file onto my fpga the monitor receives a signal, as from Blue screen(standard no signal color) it turns black and if i increase the brightness i get Vertical green lines. Do I need a frame buffer before the Video Clocked out IP. Does it make a difference if i set the Test Gen to produce interlaced frames synced on f0 or f1? I hope u can help me, will greatly appreciate it. regards nadeem
