17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoHello Gareth!
I'm using the Test Pattern Generator (from Altera) to feed the clocked video output. I configured it to generate a 720x486 pixels interlaced colorbar (F0 synchronized). The colorspace is YCbCr with 10 bits per color space using 4:2:2 sampling. The clocked video output is configured like this: Image Width: 720 pixels Image Height: 486 lines Bits per pixel per color plane: 10 Number of color planes: 2 Color plane transmission format: parallel Interlaced video checked Pixel fifo size: 720 pixels Sync signals: on separate wires The synchronization signals settings are what I need to know Using embedded sync signals the video was output perfectly, but I really need the external sync signals to drive other components Thiago
