17 years agoClocked video output
Hello I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a NTSC (4:3 525 lines) video with separate sync signals. To create the separate sync signals the wiz...
17 years agoThank you Jake and OrchestraDirector
I did try the configuration suggested in the CVTd6r1.xls but it still wouldn't work At the ug_vip.pdf I didn't find any suggestions, could you point me the exact location OrchestraDirector? Anyone used this Clocked_Video_Output with separate sync signals? Did it work? What configuration did you use? Thank you Thiago
