11 years agoClock Video Output is not working in Cyclone III FPGA
My Design consists of a clocked video output set to a resolution of 1024x768 @60Hz 65 MHz pixel clock. The data input is from the test pattern generator ip from the VIP block.
When i build the qsys and complile my design and download the sof, it (Quartus) successfully dowloads the sof into the fpga. I had connected a HSMC-GPIO daughter board to observe the signals HS,VS,DE etc on the Oscilloscope, but none of the signals were observed in the scope. I doubt my design is correct, but am not able to troubleshoot it successfully yet, I have included my entire project file with qsys file and the top level, kindly let me know what I might have done wrong, it would be of great help. Thanks, Much appreciated for your replies. Sriram.2 Replies
Learn how to simulate your design.
Check frame size you need. I see frame size generating from TPG is 1024x768, but CVO configured as 1920x1080
