14 years agoClock input port inclk[0] of PLL Error
Hi, I have the following Problem: Error (15065): Clock input port inclk[0] of PLL "DE0_Nano_uCE0_Nano_uC_inst|clocks_0:the_clocks_0|altpll: DE_Clock_Generator_Audio|altpll_o152:auto_generated|...
14 years agoYes i connect pin R8. I solved the problem but I was not a problem.In the SOPC Builder I checkd a button i should´t check.Thats all.Now everthing works fine.
But thank you for your answer.
