19 years agoClock enable bug with FIR compiler v3.3.1 and v6.1
I have found a clock enable bug with FIRs generated with FIR compiler v3.3.1 and v6.1. The bug is not present in FIR compiler v3.3.0 when fixed coefficients are used. With clken always high the FIR...
19 years agoI suggest that DO NOT play much with the enable signal and don't use as a control signal for reducing the clock rate.
