9 years agoClock_Derivered Bock Problem
Hi, I'm trying to implement a design at a sampling rate lower than the clock frequency. So i implement this by a Clock_Derivered Block. I'm using a Altera Cyclone® IV EP4CE22F17C6N FPGA. ...
9 years agoI solved it.
The Clock_Derivered Block needs an input of the crystal and on that board we only have an 50Mhz crystal source at PIN_R8. I used an DSP Builder Incrementor Block and a bus splitter for the Clock_Derivered Block and assigned to it.
