Clarification on TX/RX P&N Invert feature support in TSE IP core
- 1 year ago
Yes, when you enable the TX/RX P&N Invert options in the TSE IP Analog Parameters GUI, you must also perform the Attribute Access Method steps (as described in GTS Attribute Access Method Example 3) after entering user mode.
This requirement applies because the TSE IP uses the same underlying PMA attributes as the GTS PHY. The GUI setting alone doesn’t apply the inversion until the attribute access sequence is executed.
Sahil Patni
Thank you for your detailed reply.
Based on the following documentation:
3.3.11. Analog Parameter Options
When using the Analog Parameter GUI options to invert the PMA P and N pin polarity, it mentions that after entering user mode, the Attribute Access Method steps (as described in the “GTS Attribute Access Method Example 3” section) must be executed.
Could you please clarify if the same requirement applies when the TX/RX P&N invert options are enabled through the Analog Parameters in the TSE IP core?
In other words, is enabling these options in the GUI sufficient for the TSE IP core, or do we also need to perform additional steps similar to those required for the GTS?
Sahil Patni
- sahilpat1 year ago
I believe all your queries have been addressed.
If you have no further questions, please mark this thread as Solved for closure.If you have a new question, feel free to start a new thread to get support from Altera experts.
Sahil Patni- fa_fpga_enthusiast1 year ago
Thank you for your reply.
We will try the proposed solution in the near future.
If we encounter any issues, we’ll open a new thread.This thread can be closed for now.
