fa_fpga_enthusiast
1 year agoClarification on TX/RX P&N Invert feature support in TSE IP core
Hello, Based on the page below from the GTS Transceiver PHY User Guide: Agilex™ 5 FPGAs and SoCs (version 25.1, “Analog Parameter Options” section), the “Enable TX P&N Invert” and “Enable RX P&N Inv...
- 1 year ago
Yes, when you enable the TX/RX P&N Invert options in the TSE IP Analog Parameters GUI, you must also perform the Attribute Access Method steps (as described in GTS Attribute Access Method Example 3) after entering user mode.
This requirement applies because the TSE IP uses the same underlying PMA attributes as the GTS PHY. The GUI setting alone doesn’t apply the inversion until the attribute access sequence is executed.
Sahil Patni
Anonymous
1 year agoNot applicable
Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible
