MTwee
8 years agoChange the default mode of 1G/10G PHY-IP
Hi, I'm using 1G/10G PHY IP in my design. After power-up the IP is wake up by default in 10G mode. switching to 1G mode is done by reconfiguration of the IP (using Transciever Reconfiguration Controller). My question is how can I change the behavior so that after power up the IP would be wake up in 1G mode?
- Deshi_Intel
HI MTwee,
Unfortunately no. BY default the IP is configured to start with 10G first then to be reconfigure to desired data rate.
- MTwee
O.K,
Thanks for your answer.
regards,
Moshe
