rsing108
6 years agocan't program stratix 10 GX with pcie hard ip+ example design
I am getting the following errors while programming the Stratix 10 GX board with the PCIE hard ip+ example design.
quartus_pro 19.4
Error (18950): Device has stopped receiving configuration data ...
SengKok_L_Intel
6 years agoHi,
Can you send me your simple design 's QSF file that able to program successfully? I would like to have a look of the Power setting and see if there is any difference.
Regards -SK
- rsing1086 years ago
I am attaching the qsf file of my simple design and I am also attaching the qsf of a vendor provided design which also has pcie instantiated
- SengKok_L_Intel6 years ago
As i can see, you did not change the power and VID settings accordingly. Could you please give it a try of the attached qsf file?
Regards -SK
Hi @SengKok_L_Intel ,
The previous errors are gone but now I am getting this error:
Error (18948): Error message received from device: Device is in configuration state.
Error (209012): Operation failed
