18 years agoCan't install IP with Megawizard
Ok, I must be doing something wrong... We have a subscription license. I installed Quartus7.2 and IP7.2 and rebooted. I open a project and open Megawizard. I give the megafunction a name, scro...
18 years agoHello,
You aren't doing anything wrong, except trying to access IP cores that your license doesn't support.. When you install the complete IP library, you are installing the cores listed as installed plug-ins(i.e. the cores listed under Arithmetic, Communications, etc). The cores within the IP Megastore are all third party cores which a. are not installed as part of the library, b. not included with your altera license, and c. must be received directly via the core vendor. Hope that helps, Frank
