14 years ago
can't get any response from TSE core
hi all,
I want to use the TSE megacore without NIOS processor. The problems is that I can't get any response from the core, even when I set the tse as the top-level entity and reset it. The wave of modelsim is attached. Is there any option that I missed or wrong operation? Thanks a lot in advance.
1 Reply
    have solved the problem. it was due to the .do file generated by quartus.
    transcript on
    if {} {
    	vdel -lib rtl_work -all
    vlib rtl_work
    vmap work rtl_work
    vcom -93 -work work {D:/WyBaby/Documents/SIEMENS/FPGA/Project/9_2frame_1/src/tse_mac.vho}
    vcom -93 -work work {D:/WyBaby/Documents/SIEMENS/FPGA/Project/9_2frame_1/src/tse_mac.vhd}
    vlog -vlog01compat -work work +incdir+D:/WyBaby/Documents/SIEMENS/FPGA/Project/9_2frame_1/src/triple_speed_ethernet-library {D:/WyBaby/Documents/SIEMENS/FPGA/Project/9_2frame_1/src/triple_speed_ethernet-library/altera_tse_reset_synchronizer.v}
    vcom -93 -work work {D:/WyBaby/Documents/SIEMENS/FPGA/Project/9_2frame_1/simulation/modelsim/tse_mac_tb.vhd}
    vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive -L rtl_work -L work -voptargs="+acc" tse_mac_vhd_tst
    add wave *
    view structure
    view signals
    run 100 us
    i changed the position of line 8 and line 9 and 'do run_msim_rtl_vhdl.do', then it gave the right output.
    then what is the .vho file and how does it work? thx a lot in advance.
