Cannot Read data from MAX10 UFM
Have you selected burst count after you assert the read signal?
You may follow the user guide available at link below for the steps to perform read operation:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf (Page 16)
I believe I am following the User Guide. avmm_burstcount is set at the same time avmm_read is asserted, I'll attach a waveform.
- Stephanie5 years ago
Is there any more feedback for this issue?
I also get the following warning messages throughout the simulation:
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'the_master_to_user_fifo'. Expected 13, found 8.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/master/the_master_to_user_fifo File: C:/MAX10_work/burst_read_master.v Line: 237
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'sclr'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'eccstatus'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'full'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'almost_full'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'almost_empty'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'flash'. Expected 15, found 10.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash File: C:/MAX10_work/MAX10_work.v Line: 148
# ** Warning: (vsim-3015) [PCDPC] - Port size (17) does not match connection size (32) for port 'avmm_data_addr'. The port definition is at: C:/MAX10_work/max10_flash/simulation/max10_flash.v(13).
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_addr'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_read'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_writedata'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_readdata'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_data_writedata'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'ufm_data_shiftreg'. Expected 11, found 6.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash/onchip_flash_0/avmm_data_controller/genblk6/ufm_data_shiftreg File: C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v Line: 1175
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'shiftin'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'aset'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'sclr'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'sset'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'q'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'altera_onchip_flash_block'. Expected 18, found 17.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash/onchip_flash_0/altera_onchip_flash_block File: C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash.v Line: 302
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash.v(302): [TFMPC] - Missing connection for port 'bgpbusy'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for '<protected>'. Expected <protected>, found <protected>.
# Time: 0 ps Iteration: 0 Protected: /testbench/UUT/flash/onchip_flash_0/altera_onchip_flash_block/inst/<protected>/<protected>/<protected>/<protected>/<protected> File: $MODEL_TECH/../altera/verilog/src/mentor/fiftyfivenm_atoms_ncrypt.v Line: 38
# ** Warning: (vsim-3722) <protected>(<protected>): [TFMPC] - Missing connection for port '<protected>'.
# ** Warning: (vsim-3722) <protected>(<protected>): [TFMPC] - Missing connection for port '<protected>'.testbench.UUT.flash.onchip_flash_0.altera_onchip_flash_block.inst.<protected>.<protected>.<protected>.<protected>.<protected>.<protected>: 1.25ns: WARNING: DIN shows unknown state!
