14 years agoCan FPGA used to control powerline communications.
Can anyone help me on this ...i would like to use fpga to be used on powerline communication but im blank on how to do it......
14 years agoI am going to build this part of the project which is the OOK modulator as shown
belowhttps://www.alteraforum.com/forum/attachment.php?attachmentid=5226 and i have to interface it with a another board using RS232 male connector soe that i can attach to my DE-2 board... by exactly following the circuit can i connect to the RS232 port in my DE-2 would it work?...ive tried using LT spice for simulation purposes since im not that good on using the software i found it hard to come up with the simulation ...i am preparin to do it practically... and i have found a RS232 based verilog code in order to be test for the Tx and Rx...can this coding work for this powerline project...im connecting two ALTERA DE-2 boards using the powerline....any advise...// RS-232 TX module
//`define DEBUG // in DEBUG mode, we output one bit per clock cycle (useful for faster simulations)
module async_transmitter(clk, TxD_start, TxD_data, TxD, TxD_busy);
input clk, TxD_start;
input TxD_data;
output TxD, TxD_busy;
parameter ClkFrequency = 25000000; // 25MHz
parameter Baud = 115200;
parameter RegisterInputData = 1; // in RegisterInputData mode, the input doesn't have to stay valid while the character is been transmitted
// Baud generator
parameter BaudGeneratorAccWidth = 16;
reg BaudGeneratorAcc;
`ifdef DEBUG
wire BaudGeneratorInc = 17'h10000;
`else
wire BaudGeneratorInc = ((Baud<<(BaudGeneratorAccWidth-4))+(ClkFrequency>>5))/(ClkFrequency>>4);
`endif
wire BaudTick = BaudGeneratorAcc;
wire TxD_busy;
always @(posedge clk) if(TxD_busy) BaudGeneratorAcc <= BaudGeneratorAcc + BaudGeneratorInc;
// Transmitter state machine
reg state;
wire TxD_ready = (state==0);
assign TxD_busy = ~TxD_ready;
reg TxD_dataReg;
always @(posedge clk) if(TxD_ready & TxD_start) TxD_dataReg <= TxD_data;
wire TxD_dataD = RegisterInputData ? TxD_dataReg : TxD_data;
case(state)
4'b0000: if(TxD_start) state <= 4'b0001;
4'b0001: if(BaudTick) state <= 4'b0100;
4'b0100: if(BaudTick) state <= 4'b1000; // start
4'b1000: if(BaudTick) state <= 4'b1001; // bit 0
4'b1001: if(BaudTick) state <= 4'b1010; // bit 1
4'b1010: if(BaudTick) state <= 4'b1011; // bit 2
4'b1011: if(BaudTick) state <= 4'b1100; // bit 3
4'b1100: if(BaudTick) state <= 4'b1101; // bit 4
4'b1101: if(BaudTick) state <= 4'b1110; // bit 5
4'b1110: if(BaudTick) state <= 4'b1111; // bit 6
4'b1111: if(BaudTick) state <= 4'b0010; // bit 7
4'b0010: if(BaudTick) state <= 4'b0011; // stop1
4'b0011: if(BaudTick) state <= 4'b0000; // stop2
default: if(BaudTick) state <= 4'b0000;
endcase
// Output mux
reg muxbit;
always @( * )
case(state)
3'd0: muxbit <= TxD_dataD;
3'd1: muxbit <= TxD_dataD;
3'd2: muxbit <= TxD_dataD;
3'd3: muxbit <= TxD_dataD;
3'd4: muxbit <= TxD_dataD;
3'd5: muxbit <= TxD_dataD;
3'd6: muxbit <= TxD_dataD;
3'd7: muxbit <= TxD_dataD;
endcase
// Put together the start, data and stop bits
reg TxD;
always @(posedge clk) TxD <= (state<4) | (state & muxbit); // register the output to make it glitch free
endmodule and the receiver part // RS-232 RX module
module async_receiver(clk, RxD, RxD_data_ready, RxD_data, RxD_endofpacket, RxD_idle);
input clk, RxD;
output RxD_data_ready; // onc clock pulse when RxD_data is valid
output RxD_data;
// We also detect if a gap occurs in the received stream of characters
// That can be useful if multiple characters are sent in burst
// so that multiple characters can be treated as a "packet"
output RxD_endofpacket; // one clock pulse, when no more data is received (RxD_idle is going high)
output RxD_idle; // no data is being received
// Baud generator (we use 8 times oversampling)
parameter Baud8 = Baud*8;
parameter Baud8GeneratorAccWidth = 16;
wire Baud8GeneratorInc = ((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7);
reg Baud8GeneratorAcc;
always @(posedge clk) Baud8GeneratorAcc <= Baud8GeneratorAcc + Baud8GeneratorInc;
wire Baud8Tick = Baud8GeneratorAcc;
reg RxD_sync_inv;
always @(posedge clk) if(Baud8Tick) RxD_sync_inv <= {RxD_sync_inv, ~RxD};
// we invert RxD, so that the idle becomes "0", to prevent a phantom character to be received at startup
reg RxD_cnt_inv;
reg RxD_bit_inv;
if(Baud8Tick)
begin
if( RxD_sync_inv && RxD_cnt_inv!=2'b11) RxD_cnt_inv <= RxD_cnt_inv + 2'h1;
else
if(~RxD_sync_inv && RxD_cnt_inv!=2'b00) RxD_cnt_inv <= RxD_cnt_inv - 2'h1;
if(RxD_cnt_inv==2'b00) RxD_bit_inv <= 1'b0;
else
if(RxD_cnt_inv==2'b11) RxD_bit_inv <= 1'b1;
end
reg state;
reg bit_spacing;
// "next_bit" controls when the data sampling occurs
// depending on how noisy the RxD is, different values might work better
// with a clean connection, values from 8 to 11 work
wire next_bit = (bit_spacing==4'd10);
if(state==0)
bit_spacing <= 4'b0000;
else
if(Baud8Tick)
bit_spacing <= {bit_spacing + 4'b0001} | {bit_spacing, 3'b000};
if(Baud8Tick)
case(state)
4'b0000: if(RxD_bit_inv) state <= 4'b1000; // start bit found?
4'b1000: if(next_bit) state <= 4'b1001; // bit 0
4'b1001: if(next_bit) state <= 4'b1010; // bit 1
4'b1010: if(next_bit) state <= 4'b1011; // bit 2
4'b1011: if(next_bit) state <= 4'b1100; // bit 3
4'b1100: if(next_bit) state <= 4'b1101; // bit 4
4'b1101: if(next_bit) state <= 4'b1110; // bit 5
4'b1110: if(next_bit) state <= 4'b1111; // bit 6
4'b1111: if(next_bit) state <= 4'b0001; // bit 7
4'b0001: if(next_bit) state <= 4'b0000; // stop bit
default: state <= 4'b0000;
endcase
reg RxD_data;
if(Baud8Tick && next_bit && state) RxD_data <= {~RxD_bit_inv, RxD_data};
reg RxD_data_ready, RxD_data_error;
begin
RxD_data_ready <= (Baud8Tick && next_bit && state==4'b0001 && ~RxD_bit_inv); // ready only if the stop bit is received
RxD_data_error <= (Baud8Tick && next_bit && state==4'b0001 && RxD_bit_inv); // error if the stop bit is not received
end
reg gap_count;
always @(posedge clk) if (state!=0) gap_count<=5'h00; else if(Baud8Tick & ~gap_count) gap_count <= gap_count + 5'h01;
assign RxD_idle = gap_count;
reg RxD_endofpacket; always @(posedge clk) RxD_endofpacket <= Baud8Tick & (gap_count==5'h0F);
endmodule
