14 years agoCan FPGA used to control powerline communications.
Can anyone help me on this ...i would like to use fpga to be used on powerline communication but im blank on how to do it......
14 years agohow can i come across for the verilog coding as i am using the de-2 board ...how can i manipulate the rs232 pin to be the transmitter...
--- Quote Start --- Try something out. If you use a buffer board between your DE2 and your test circuits, then the worst you can do is destroy the buffer board --- Quote End --- and what type of buffer board can i prepare for this...
