14 years agoCan FPGA used to control powerline communications.
Can anyone help me on this ...i would like to use fpga to be used on powerline communication but im blank on how to do it......
14 years ago --- Quote Start --- i have a DE2 board which consist cyclone 2 ...can i use the board to test the likewise circuit.. --- Quote End --- That would meet the requirement of 'any FPGA board'. --- Quote Start --- Any idea how the circuit looks like if i want to replace the PIC.... --- Quote End --- Look at the PIC circuit. Make sure you protect the FPGA I/O. Check that voltages are compatible. Add buffers where they are not. Simulate the analog circuit using LTSpice. Try something out. If you use a buffer board between your DE2 and your test circuits, then the worst you can do is destroy the buffer board. Its time to roll up your sleeves and do something :) Cheers, Dave
