corestar's avatar
corestar
3 months ago
Can an Application Ignore PCIe flow Control Credits?
I'm using a Cyclone V GT with PCIe core using Gen 1 Avalon-ST 64-bit endpoint interface. Occasionally packet sending would stall and I had thought it was because I was ignoring the flow control credits. But after properly handling tx_st_ready going low, the problem seems to have gone away.
So the question is can I ignore the flow control signals as long as I throttle the sending when tx_st_ready goes low?
In the flow control section of the UG-011110 dated 2020.06.02, it says
That is not important for our application. But then after spending several paragraphs explaining how the PCIe Hard IP tracks and checks credits, it make says:
Can I assume that is only in the case described in the yellow highlight?
Also, in the flow control update loop description, is says:
Is that where the Hard IP is lowering tx_st_ready so the App is indirectly handling credits?
If so, one odd thing is that sometimes tx_st_ready does not go low until toward the end of a packet write (ie closer to the EOP and the SOP). I would think it would do the credit check as soon as it had the TLP headers which contain the type, number of dwords etc.
Just a suggestion, but for Apps that did want to optimize throughput, it would have been helpful to just expose the credit limits to the App instead of making it independently keep track of them. The credit system is a bit confusing.
  • Hi corestar,
    My apologies on the delayed response.
    Yes, the flow control signal (tx_cred_*) can be ignored and honoring tx_st_ready is sufficient. The Hard IP performs the mandatory PCIe credit check on every TLP internally; if credits are short it blocks the TLP (and all following ones) and expresses that back-pressure solely by deasserting tx_st_ready. The flow control signals are needed to track credits to optimize the throughput, which is optional.
    Regarding the credit limits, the Avalon-ST TX datapath does expose them. The six credit limit signals tx_cred_hdrfcp/datafcp, tx_cred_hdrfcnp/datafcnp, tx_cred_hdrfccp/datafccp carry the current per-type credit limits; the tx_cred_fchipcons strobes each credit the Hard IP consumes; and tx_cred_fc_infinite flags infinite types.
    Ven
  • Hello VenT_Altera​
    That gives me all the info I needed. It seems to work very reliably by just handling the tx_st_ready.
    I would suggest they change the wording of:
    Note: You must keep track of the credits consumed by the Application Layer.
    to
    Note: If you want to optimize packet ordering, you must keep track of the credits consumed by the Application Layer.
    Dave
    • VenT_Altera's avatar
      VenT_Altera
      Hi corestar,
      Thank you for your feedback and suggestion to improve the user guide for better clarity and readability.
      I appreciate you taking the time to share your suggestion. I will relay your suggestion to the internal team for their consideration and review in future documentation updates.
      Ven
    VenT_Altera
    Hi corestar,
    As there are no further inquiries, I will transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Altera experts.
    Have a great day!
    Ven
    VenT_Altera
    Hi corestar,
    Ven
    VenT_Altera
    Hi corestar
    Thank you for your question. I will go through your enquiry and get back to you soon.
    Ven Ting
