NGagl
8 years agoCalibration failing for DDR2 Memory Controller on Cyclone V
I'm having trouble implementing the example project generated when instantiating a DDR2 interace on a Cyclone V device on a custom board. At this point, I am trying to create a soft memory interface...
Deshi_Intel
7 years agoHi Nick,
Assume you have key in all the correct DDR2 setting in DDR2 IP, then the easiest way to debug is to use DDR2 example design generated from DDR2 IP.
If example design passed - then most likely is your board design issue
If example design failed - then it could be DDR2 IP setting or board design issue.
Deshi
