17 years agoCalculate Maximum with DSP builder
Hi, I have to calculate the delay between 2 signals so I've done a crosscorrelation. After that I have to calculate the index of the maximum for each window, I've done it in Simulink and I'm ...
17 years agoI am a bit unsure what is the requirement of this design. If you just want to
find the maximum(or minimum) of a given sequence of data then you can do that readily in HDL(I rather go simulink path for the really hard stuff). For example if your signal is "data_in" and it is std_logic_vector(15 downto 0) then to get the maximum value: ***************************** signal max_pos : signed(15 downto 0); ------ data_in_signed <= signed(data_in); ------ process(reset, clk) begin if(reset = '1')then max_pos <= (others => '0'); elsif(rising_edge(clk))then if(data_in_signed > max_pos)then max_pos <= data_in_signed; end if; end if; end process; maximum <= std_logic_vector(max_pos); ******************************** Similarly for minimum: signal max_neg : signed(15 downto 0); process(reset, clk) begin if(reset = '1')then max_neg <= (others => '0'); elsif(rising_edge(clk))then if(data_in_signed < max_neg)then max_neg <= data_in_signed; end if; end if; end process; minimum <= std_logic_vector(max_neg); You can use the reset to clear the value and restart at any point e.g. per packet.
