14 years agocacheable PCIe BAR
Is it possible to make BAR cacheable for PCIe hard macro on Stratix IV attached to standard PC with Intel processor? Anything special needs to be done in the driver for such case? Thanks!
14 years agoI know about DMA and that it would be more efficient. However, in this case the goal is different - neither efficiency, no consistency are the issues.
pgprot_noncached() is equivalent to setting _PAGE_PCD | _PAGE_PWT flags in CentOS 5 for x86: include/asm-x86_64/pgtable.h:314:#define pgprot_noncached(prot) (__pgprot(pgprot_val(prot) | _PAGE_PCD | _PAGE_PWT)) I verified that these flags are not set when mmap() is called/executed. I think it might be a HW issue. I found the following document that says that a particular PCIe device implementation is not cacheable due to implementation limitation: TI document "KeyStone Architecture Peripheral Component Interconnect Express (PCIe)": --- Quote Start --- No support for addressing modes other than incremental for burst transactions. Thus, the PCIe addresses cannot be in cacheable memory space --- Quote End --- Apparently, PCI had support for cache line access: Wikipedia article about Conventional_PCI#Burst_addressing So, I am wondering whether Stratix IV implementation of PCIe has any limitations/issues that does not allow it to work correctly with processor caching. P.S. Mmapping /dev/mem at PCIe BAR address was also tried with the same result: reads work as expected, writes cause system reboot.
