14 years agocacheable PCIe BAR
Is it possible to make BAR cacheable for PCIe hard macro on Stratix IV attached to standard PC with Intel processor? Anything special needs to be done in the driver for such case? Thanks!
14 years agoBy cacheable BAR I mean BAR that can be cached by Intel processor cache.
Typically, BARs are not cached by processor cache, however, in this case caching is desirable. I am using Linux, CentOS 5 (2.6.18). I modified MTRR settings to exclude the BAR from uncached regions. Also, I wrote a driver that creates bin_attribute in /sys/... with custom mmap() function that maps the BAR into user space without setting _PAGE_PCD | _PAGE_PWT page flags. When the BAR is mmaped into user space I can issue reads to it and observed caching behavior, i.e. 2nd read to same address does not go to FPGA. However, when I am trying to issue a write the same BAR, the system reboots without any message on the screen or in the logs. So, I am wondering whether I am doing something wrong in the driver/settings or Stratix IV PCIe implementation does not support some feature, which is needed for this to work properly?
