14 years agobyte enables output of PICe
Hi;
I found in Altera's PCIE core that they use a separate byte enable signal for rx side avalon. This signal is not present in Xilinx's PCIE core. In Altera's PCIE user-guide, I didn't found anything about the validity of byte enable for "completion" TLPs. Only thing mentioned is that these byte enable signals are same as we found in Memory read/write TLPs. But since completion TLPs dont contain any byte enable signals can we safely use that byte enable signal to decode data from completion TLP?? ThanksNo RepliesBe the first to reply
