8 years agoButterworth Low Pass filter Implementation
Hi, In my application I need to implement high order Butterworth Low Pass filter to ~1Hz from 32bits, ~50ksps input signal. How can I evaluate the filter performance and estimate the resources...
8 years ago --- Quote Start --- Might be. My first point was to clarify that a low-pass filter can be designed with the FIR II compiler, but fs/fc of 50k is only feasible as multi-rate design. I agree with kaz, that IIR is the better choice in this case. I feeled obliged to mention, that IIR implementation with high fs/fc ratio involves some problems too. A standard digital implementation of the second order building block for 1Hz@50kS/s needs about 27 extra fractional bits in the internal registers to avoid quantization errors. But that's manageable. I also agree that you should give a filter specification. --- Quote End --- Hi, Interesting... how did you calculate the "27 extra fractional bits in the internal registers" from the 1Hz@50kS/s requirement? I'm now working to simulate it in the Simulink environment using DSP builder. Will I see those kind of restriction? Idan
